CVD binding
I have some binding occuring and i dont know how to fix it, i am using Rd-Logics cvd's and are great by the way but the cvd is binding with the upper arm (g-maxx arm) . The whole cvd is ok, i am talking about the yoke or whatevr you call it.
I don't quite understand what is binding. Is it the drive cups?
yes, thats the word, how do i fix this? i have already scrached my arm really bad because of it,
Limit your down travel. Your arms shouldn't droop low enough to cause this. You can move the shocks so the down travel is less (move upper part of shock towards the inside of the truck) . You could also move the bottom of the shock outwards to accomplish the same thing. If these tips don't work, you will have to install limiters inside the shocks, but you should be able to work it out.
thanks Mike, i have just lowered my truck , it worked! Thanks for the help , its back up and running, ill be getting those parts i needed from you soon, could you hold those 2 integy blue cases for me? beacause i noticed you only have 2 left.
I put these aside for you and updated my inventory to reflect this (so I won't sell them). Glad you got the "little bug" worked out!
thanks mike, i will inform you when i will place an order for my stuff.
| All times are GMT -4. The time now is 06:36 AM. |
