wheelie bar problems and solution
I purchased this wheelie bar. After a while the WB started pushing up against the skid plate. It made far very long wheelies, but was ruining the tires and bending the bulkhead screws.
http://i71.photobucket.com/albums/i1...e/P1010303.jpg Next, I used a long screw rod with four tires and it really bent up everything. http://i71.photobucket.com/albums/i1...e/P1010325.jpg Here is the threaded rod used with the four tires. Notice the 2 WB tires :005: http://i71.photobucket.com/albums/i1...e/P1010011.jpg So here is my solution. I used shorter bolts and nuts to secure the WB to the bulks and went with two tires. http://i71.photobucket.com/albums/i1...e/P1010009.jpg Notice I removed the bulkhead braces. Do you guys think this will cause a problem with my hybrid bulkheads? http://i71.photobucket.com/albums/i1...e/P1010005.jpg |
Not with the bulkless. Looks good! What BL setup are you running?
Im running a 9xl, 9920 esc, 51 spur, 16/18/20t pinions, strobe slipper, single speed tranny, UE 8 spyders and 3300 to 4300Mah 16 cells packs. It rips booty :027: and tears up wheelie bars:D
Lol. Most people don't even run the braces with the bulkless to be honest. So you should be ok.
| All times are GMT -4. The time now is 12:51 PM. |
