-   GorillaMaxx (https://www.rc-monster.com/forum/forumdisplay.php?f=16)
-   -   G2R Driveshafts??? (https://www.rc-monster.com/forum/showthread.php?t=3727)
bluonyx 08.02.2006 02:09 AM
G2R Driveshafts???
After my first test bash I noticed that the driveshafts were binding or there was to much play in the cups. The shafts had peices missing or gouges out of them. I know this is not normal?:002:
http://img83.imageshack.us/img83/182...ones002up2.jpg
Will adding some fuel tubing or the O-ring trick solve this problem?
RC-Monster Mike 08.02.2006 10:23 AM
Yes, spacing the drive shafts with a small bit of fuel tubing will properly center the shafts inside the cups. The shafts are a little short to facilitate removing the tranny without disassembling the front or rear of the truck.
crazyjr 08.04.2006 11:22 PM
I havent had a problem with mine and i don't use fuel line
Serum 08.06.2006 04:46 AM
You better use it crazy.
a driveshaft needs to be centered or pushed to one side, depending on the design.
bluonyx 08.06.2006 11:36 PM
I used a small piece of fuel tubing on each side of the driveshaft and what a difference, no more clunking noise and the shafts aren't binding anymoe either. The motor and ESC ran cooler and I was able to get a longer run time. I ran a 14T pinion and temps never got over 110 degrees. Cutting the right length of tubing for each cup took a little time but was well worth it. Thanks guys!
fagzz 08.07.2006 07:04 AM
can someone post a pic of the fuel tubing mod please?
Serum 08.07.2006 12:22 PM
It's quite simple;
put a piece of fuel hose inside the cup. Use large diameter fuel hose for the best result
bluonyx 08.09.2006 01:44 AM
I'll post a pic 4 u tomorrow.
fagzz 08.09.2006 01:46 AM
thank u! ;)
bluonyx 08.09.2006 10:35 AM
If you look inside the cups you can see the fuel tubing.
http://img279.imageshack.us/img279/4...bing004gi5.jpg
http://img244.imageshack.us/img244/2...bing002hh4.jpg
fagzz 08.09.2006 11:10 AM
yes i understand! what a good idea! i will try it tonight!
All thanks Blonyx ;)
TraxxMaxx 08.12.2006 12:01 PM
The original plastic REVO driveshafs, I reckon, are much better than the supplied Gorillamaxx shafts. They work perfectly and are much less noisy - they are also considerably lighter. You will have to buy one or two extra parts to do the conversion, but well worth it!!
bluonyx 08.12.2006 06:55 PM
I figure if the gorilla's goes out on me, I have a set if the 3.3's in the toolbox. They are much lighter than these.
RC-Monster Mike 08.14.2006 11:02 AM
I am pretty sure the stock Revo shafts won't fit due to clearance issues(too large diameter), which is why the dogbones are included with the G2R kit.
BP-Revo 08.14.2006 12:20 PM
Hmm, seems like something I would need to do.
Anyone have a link to "large-diameter" fuel tubing?
