1950/8 coming into stock soon?
I'm thinking of getting a 125b and 1950/8 combo but the 1950/8 are out of stock. Any idea when more might be coming? How will the 1950/8 compare to a 7XL?
I'm going to use 4s lipo for now, even so though, the 7XL/9920 combo I have now is really fast but runs way too hot. Don't need quite as much speed, and would like to lose lots of heat. Could always go 5~6s for speed runs later.:027: Thanks. |
The 1950 8t is closer to a 9xl than 7xl. It just runs cooler with a little more umph.
You surely will find it a really great motor. Tons of power without heating up.
You also can keep high final ratios if your controller can handle it. I'ts a pleasure of motor. I just advice you to buy the hi-amp version. You surely won't need to change the motor to a 30 volts one and the female connectors on the non hi-amp version are not so good. I think it would be better to directly solder the esc to the motor as the hi-amp version oblige you to do. Ciao Daniele |
Should be perfect! When are they coming in? |
| All times are GMT -4. The time now is 02:00 AM. |
