lighting diffs for e-maxx
can you guys clue me in on these diffs, i need to up grade and i liked that the gear ratio was lower
First off, there great diffs. Especially for the price. Are you talking about the standards or the Pro's? The Pros are good for a truggy but would require VERY tall gearing. I recommend the standard with the FLM Hybrid bulkheads.
do you know the ratio for both , i saw that there was two different item #s for the diffs mike is selling with no ratio, i'm tired of stripping rrp gears, are they sealed for diff fluid,also i mostly do bashing and run big tires so the lower ratio gears would be best , but could i gear it for speed as well
thanks |
Pros are 4.3 to 1
the others are 3.31 to 1 |
The Pro's would be to low either way. The standard buggy diffs are the way to go. The only reason to get the Pros is if your running a center diff. BTW, what setup are you running?
| All times are GMT -4. The time now is 04:20 PM. |
