-   -   esc for feigao (https://www.rc-monster.com/forum/showthread.php?t=3760)
cliccker985 08.06.2006 04:42 PM
esc for feigao
iwas looking at some brushless motors on ebay and was wondering what kind of esc i could use that 14 cells and Feigao 8 XL Brushless Motor that doesn't cost over $250.00:027: :032: :018: :eek:
squeeforever 08.06.2006 05:01 PM
For $280 you could get the Quark 125. Its well worth the extra $$. If you can't get the 125, the Warrior 9920 is next best.
Serum 08.07.2006 05:34 AM
9920 would fit nicely in your budget.
If you want to go lipo in the future, go with the quark 125, it has got a built in cut-off, which you need to buy seperate with the 9920.
The quark 125 hasn't got a reverse brake though. Something to notice.
You will love that 8XL on 14 cells. It's a good motor. Try it with 16 too!
coolhandcountry 08.07.2006 08:23 AM
You can look at the mgm 160 16 as well. It has the built in lvc for lipo as well. Has a higher amp rating to. Just 5s or 16 cells is the down fall. Then again I have heard some people have problems with the quarks on 6s lipo. Me as one of them.
Procharged5.0 08.07.2006 01:10 PM
What are the brakes like on the MGM 160? Also, is it as programmable as the Quark 125B?
go4gold 08.07.2006 02:34 PM
The9920(189.00) is a good solid esc and will work great with that motor on 12-16 cells. You will also need an ubec(37.00). Are you looking at the 8xl for 59.95? Do a search on here for all the different controllers to read what people are saying about thembefore choosing 1. Sometimes it really pays off to spend a little extra nowcause you may end up spending it later anyway.
Rtsbasic 08.07.2006 03:55 PM
I run a 9920 and 9XL on varying voltages, and can't really fault it. If driven hard enough the whole setup will get pretty hot, but I don't think theres many esc's that wouldn't. The 9920 does have stuttering at low speeds, but I can drive it around my kitchen without it presenting a problem, so I doubt it'll cause you any :) I purchased a seperate LVC to use with it (can be had for $12 or so..see the LVC thread in the electronics section).
