grind motor shaft?
I suppose I grind a flat on the shaft for the grub screw because massive amount of power? Or is there a better way?
I reckon to do it with all motors. And I’ll watch the filings so they won't get into the motor....it looks really sealed anyway but better to be safe than sorry:027: |
i put a piece of plastic isolation tape over the bearing, and press the hole in it for the shaft. Keeps him nice and sealed.
You indeed need to grind a notch onto it. |
thanks
| All times are GMT -4. The time now is 11:35 AM. |
