-   -   7XL 0r 9L with BK 9920 on LIPO? (https://www.rc-monster.com/forum/showthread.php?t=3819)
rchippie 08.14.2006 02:13 PM
Would a 4s lipo pack be ok to use in my EVO or RACEBOMB with the stuff mentioned titled ?. Also i would use a trition charger because thats what i have.
captain harlock 08.14.2006 02:23 PM
No problem at all, rcheppie.
coolhandcountry 08.14.2006 02:30 PM
Make sure you get a low voltage cut off or detector.
rchippie 08.14.2006 02:40 PM
Would the trition charger be okay also ?. Maxxamps has a 4000 4s pack that i was looking at. Are there any other 4s packs in that price range ?.
coolhandcountry 08.14.2006 03:36 PM
That is fine for the triton. It can do 4s but only at 2.5 amp.
squeeforever 08.14.2006 07:14 PM
Hippie, are you gonna get 2 2S packs or one 4S?
rchippie 08.14.2006 07:35 PM
If i do it i will get one 4s pack. Maxxamps said they can make me a 6000mah 4s pack.
squeeforever 08.14.2006 08:16 PM
Wouldn't you be throwing off your weight distribution?
rchippie 08.14.2006 09:43 PM
Yes it would i just dont know which is the better way to go for me. Two packs costs more than one.
Could i use two 2s2p 8000mah packs in my EVO or RACEBOMB, or is a single 4s pack better ?.
squeeforever 08.14.2006 10:04 PM
There actually gonna be the same thing, just in different configurations. I would go with the 2S2P packs. It shouldn't cost any more. Maybe, 5 or 10 dollars for the wire, connectors, heatshrink, ect.
coolhandcountry 08.14.2006 10:10 PM
You could go smaller 2s packs like the 6000 for weight. They 80 a pop verse 110 to. Get two packs for 4s 2p 6000 mah. for under 600 grams of weight.
rchippie 08.15.2006 12:06 PM
If i go with either two packs of (6000 2s2p) or two packs of (8000 2s2p) can i charge both of them at the same time on my triton charger ?.
coolhandcountry 08.15.2006 01:38 PM
Well that is up to you. Some say yes some say no. It would be faster to charge them in series. I would stop them before full and charge seperate to the full charge.
rchippie 08.15.2006 01:57 PM
Leroy if i chrage them both at the same time by a jumper from the charger they would be in series.
neweuser 08.15.2006 02:35 PM
Yes, that would be in series. But with the Lipo packs, i would charge individually with triton charger. IMHO
