-   -   Novak 4.5 (https://www.rc-monster.com/forum/showthread.php?t=3904)
peppy211 08.25.2006 11:37 AM
Novak 4.5
could i use lipo batterie with the new novak 4.5 system?? thanks
neweuser 08.25.2006 11:38 AM
I heard that you can, but need to watch what voltage you're running thru the esc...
coolhandcountry 08.25.2006 11:48 AM
I seen some one run lipos on the orginal hv maxx. I would suggest wiring a
LVC up in the system. That away no worries on damaging the batts.
SpEEdyBL 08.25.2006 09:41 PM
Yes, you can use 2s 7.4 lipos with a Low voltage cut-off device that cuts power to the motor when the pack drops to 6 volts.
