radio interferance prob's !
Hi !
I have a big problem with interferance from my new mambamax system in my rust'y :019: because if i run my rust over 10meters from me the motor start's cogging badly !! what coud cause this ? the motor runs great with in 8-10meters!!! |
Check the antenna not messed up.
Make sure wires not run to close to rx. What kind of radio? |
problem solved ! i changed tx and the problem's disapeared :027:
now i run the stock traxxas tx and rx. But one thing still trubles me ! the motor seem's to reacting slower to trottle inputs ? it getts a little better when i set the trottel trim to a lite above neutral. i,ve re calibrated the esc after the tx change som the esc coud know were the endpoint's for the new tx are ! it's still very driviable so it's no bigg'y but still strange to me:027: . o and a new Q ! how much coud i gear down to be able to run my proline sandpaw tires ? now i run the stock rust'y tire's and 16/86 gearing.the motor stays around 100F runnin on gras and gravel. |
I eouldn't change the gearing, try it first and if you don't like the temps then re gear.
| All times are GMT -4. The time now is 08:37 PM. |
