simple question...
hi guys, i just wondered if i was supposed to recalibrate my 9920 controler to run my new Feigao7XL motor? I ran a 9L before...
Thanks for the help! :032: |
Yea. You might want to reprogram it.
If you running the same radio and truck. I don't see no need. You can though.
imo if i keep the same tx and rx, there is no need... but i don't want to do bad... therefore i will recalibrate the controler...
tks for all... |
does the calibration consider only TX EPAs??? or does it measure the motor parameters???
Calibration only uses the TX EPA.
therefore there is no need to recalibrate my BK9920 controler to run another motor on it? that's not clear...
When you calabrate the esc. It only reads the tx (radio transmitter). It don't read nothing from motor side.
| All times are GMT -4. The time now is 02:59 PM. |
