Flipping Tranny
I'm converting my girls truck to BL. The one thing i want to do is flip the tranny, but not sure if that would work. I want the motor to be towards the back and not the front. Is this possible? I'm thinking i can but need to flip the diffs too? thanks!
If you run brushless no need to flip diffs. The thing you have to do is run a shifting linkage to the servo to shifting fork. That is worst part.
I wouldn't even run a shifting servo.
I'm using a single speed, so no worries there! thanks guys!
if you flip the diffs it will work, if you are using Novak hv or titans. Other brushless just change two wires and leave the diffs alone. I did it myself with titans and hv brushless, but not with unsensored
| All times are GMT -4. The time now is 04:05 AM. |
