-   -   I received my BL ! What I should do??! (https://www.rc-monster.com/forum/showthread.php?t=399)
Quebecois_Sti 03.29.2005 05:33 PM
Hello,
I just received my BL order (MGM controller 80 amp with Feigao 8s), good job Rc-Monster, well packed and fast shipping (in 5 days to Canada).
Now I want to know where to weld the motor on the speed control ?
There is "A" "B" "C" connections (yellow wire) on the controller and the motor is with wire red, green and yellow. Where I weld it ? Any where to any connections ?
Nick 03.29.2005 05:39 PM
It is best to solder the ESC straight to the motor with no connectors, this gives less resistance.
Sorry I know little about anything else - just a quick reply so you can try and get the beast running. :P
phildogg 03.29.2005 05:42 PM
just hhok up the three wires to the three blue wires coming off the controller,if the motor runs in reverse just change two wires around. then you need to program the controller to your radio. there are instructions on the site for the programming hope this helps ya some.
phil
HotnCold 03.29.2005 05:51 PM
Pdog is correct - if your motor is running backwards - changing 2 leads will correct the prob - any two leads will do....
Quebecois_Sti 03.29.2005 06:14 PM
I don't find the instructions/user guide on the site, only user guide for the Warrior...
I plug the yellow wires of the controller to any wire of the motor ? It cannot break something ?? I don't understand so much what you are talking about (I'm not so good in English...)
HotnCold 03.29.2005 06:25 PM
Yes - the 3 wires from motor to the 3 motor leads on controller - if motor is spinning the wrong way - change any 2 of the wires...
Quebecois_Sti 03.29.2005 06:50 PM
ok..
I check and at the begin, the motor was turning and I was checking in what way to be. I find the correct turning way but I just go take a pinion to be sure of the way and now the controller is always do : BEEP BEEP BEEP and the green LED is flashing at the same time. My throttle of my transmitter is to the lower. And after if my problem will be fix, how I will adjust the controller to my transmitter ? I have no user guide give with and I search few minutes on google and I found nothing.
thx to help. I want to test it :D
HotnCold 03.29.2005 07:03 PM
1 second for the fix
Quebecois_Sti 03.29.2005 07:07 PM
I think I find the user guide !
is it this : http://www.wattsup.co.nz/pdfs/TMMEXP...manual_ENG.pdf
RC-Monster Mike 03.29.2005 07:13 PM
I just e-mailed the instruction. That link is also the instructions (this is in your e-mail). LMK if you need any further assistance.
phildogg 03.29.2005 07:43 PM
sorry bro I thought you had the bk controller ..oops my fault.
phil
Quebecois_Sti 03.29.2005 08:33 PM
thats ok now...!
Thanks Mike for the fast support!
My car is now ready, I will try it!
RC-Monster Mike 03.29.2005 08:41 PM
Have fun!
