-   -   Center diff for brushless (https://www.rc-monster.com/forum/showthread.php?t=3992)
Rcbros 09.05.2006 05:52 PM
Hey Guys. I need a truggy diff for a brushless conversion i'm doing.
What center diff would you use and what plastic spur gears fit it?
squeeforever 09.05.2006 06:41 PM
The Ultra MBX Ofna diff uses the same spur as a Strobe slipper... That should work nicely...
coolhandcountry 09.05.2006 07:42 PM
That is the one I use. You can get the koyosho spur for some diffs to. But it is a little smaller. It is easier to mount in some locations though.
MetalMan 09.05.2006 10:20 PM
Another option is a Hyper 7 or Kyosho 1/8 buggy diff for use with the Kyosho plastic spur gears (44t and 46t) that Mike sells. They use the more common 8x16mm bearings, whereas the Ofna MBX diff uses 7x14mm bearings (or something like that). I have a Hyper 8 diff/Kyosho 46t spur in my BL/Lipo 1/8 buggy right now, and it's doing fine so far.
Rcbros 09.05.2006 10:52 PM
Can you probably gear a truggy with only a 44 or 46 tooth spur?
I always thought truggys use a larger spur then the buggys.
would it be bad to run a steel spur?
squeeforever 09.05.2006 11:03 PM
Yes, you can gear one properly, but it would be alot easier with something like the LSP diffs. The Lightning Stadium comes with 4.3 to 1 ratio diffs instead of 3.31 like buggys and alot of truggies. Alot of the earlier truggies did indeed use a 60+ tooth spur. I wouldn't recommend a steel spur. The steel spur would require hardened pinions and there quite expensive and aren't the best way to go. Plastic spur is definately the way to go...
glassdoctor 09.05.2006 11:18 PM
If you use a low kv motor it's no problem.
It would be tough to properly gear a 3000+kv motor in a truggy with a 44 or 46 tooth gear, unless you are only wanting to do speed runs.
But a 2000kv motor is much better suited to this app imo... not a problem to gear for "normal" or "sane" speeds.
Rcbros 09.06.2006 01:12 AM
squee, So the plastic spur will work with the LSP diff?
Glassdoctor,
I'll be using it for racing and running lipos. I plan and hope to get 30minutes or more run time out of it.
Rcbros 09.06.2006 12:31 PM
So I can go with a Kyosho Diff and use a 44T or 46T pinion.
Or I can get the ofna 51T pinion.
If and when they are out, I will be using the truggy diffs that mike sells for the revo.
If it was use which diff setup would you go with? I'm trying to get closest to the appropriate gearing as possible.
I just came across these spur gears. Do they look like they may fit?
http://www.rcmart.com/catalog/produc...033ef57c118a20
cart213 09.06.2006 01:18 PM
Btw, the Thunder Tiger ST-1 also has 4.3:1 diffs, and its center diff will accept the plastic Kyosho spurs also.
glassdoctor 09.06.2006 01:40 PM
What truggy? Jammin diffs are identical to Kyoshos fyi...
coolhandcountry 09.06.2006 01:41 PM
That spur is only 48p. That would get destroyed quick like.
BitHed 11.07.2006 09:20 PM
...A KYOSHO 46t will fit the Hellfire diff with no mods...A hellfire is 4.0:1 stock (52/13)...Fitting the 46t with a 12t pinion will give you 3.8:1 and fitting an 11t will give you 4.2:1; or thereabouts :D
JThiessen 11.22.2006 02:35 PM
What do you guys think of using the center diff from all wheel drive carpet racer rides in a truggy application?
