Mike, can you make this?
hey mike,
i really need a good way to mount a wing to my truck with the knucklehead towers. i was wondering if you could make a plate like this http://www.unlimitedengineering.com/.../Wingmount.jpg . thanks |
I am sure I "can" make that. I usually just mount the wing using the upper bulkhead screws (put screws though wing, then through the shock tower and into the bulkhead. I use zip ties for the bottom of the wing, which gives it some flex. It works great.
alright mike, ill try that. which wing and mount should i use? where is the best place to get them?
i think the wing mount is from an ofna mbx buggy or something like that. Any wing mount that screws to a buggy shock tower will work fine. I think the Hot boddies wing mount would work very well, and I think I have one in stock.
how much for the wing and mount? i will buy one of you
The mount is about $5.50. A wing is $6.00.
so can i send you 11.50 plus shipping for your wing and mount you have? (if you do have it)
Sure. $3.85 for priority shipping. I have a yellow wing in stock (as well as the wing mount).
nevermind mike, i found a wing i had for my hyper and the mount was broken but it didnt matter and i got it mounted on very nicely. thanks for your help, your idea worked awesome!
Cool. Glad I could help.
| All times are GMT -4. The time now is 08:47 AM. |
