-   -   motor for novak ss+? (https://www.rc-monster.com/forum/showthread.php?t=4033)
Giller 09.12.2006 06:31 PM
i recently got a novak super sport plus brushless esc, and i have not yet purchased a brushless motor for it, but have been anxious to, before i do i was wondering wat else is out there besides the novak ss5800, mainly looking for the best and fasted out there for the money that i can run with the novak super sport plus esc?
squeeforever 09.12.2006 06:33 PM
That would be one of the several Novak motors, or possible a LRP, but I'm not sure about the LRP since the sensor wire plugs might be different...
Giller 09.12.2006 06:45 PM
which novak motor would u recomend?
squeeforever 09.12.2006 07:13 PM
To be honest, I would go for the SS5800. It would be a nice quick motor.
Giller 09.12.2006 07:18 PM
ok thanks, and would u know of any not too high priced batteries and charger u would recomend for this set up too, (planning on running this in a xxxbk2 or 1/10 4 wheel drive buggy)
squeeforever 09.12.2006 07:29 PM
If you don't have either a charger nor batteries, I would go LiPo. 2S 8000mah LiPo from MaxAmps and a Multiplex charge would be a good setup. You will need a LVC and a balancer.
Giller 09.12.2006 07:34 PM
ya right now i just have a couple 3000 epic battery packs and an old einstein charger so i think im ready for an upgrade, il definately look into the lipos iv been hearing a lot about them, just not quite sure if i can afford them ha, thanks
squeeforever 09.12.2006 07:54 PM
No problem. I actually recommended a fairly affordable setup. The batter is about $110 and the charger is around $75.
Giller 09.13.2006 06:08 PM
oh ya i found both for pretty much those exact prices, and wat is the lvc and and balancer u said i will need?
squeeforever 09.13.2006 06:10 PM
You will need a LVC (low voltage cutoff) to cut the power to the motor when the pack reaches the minimum voltage so as not to ruin the batteries. You will also need a balancer to balance the cells in the pack while its charging as not to create a large imbalance and ruin the cells.
