-   -   Its complete (https://www.rc-monster.com/forum/showthread.php?t=4070)
Puttinstankonia 09.16.2006 11:05 PM
Its complete
Thank you guys for all of your advice. With your help i am now running in a 1/10th scale tourer
lehner 4200 xl basic
Jaco Foams
Quark 125B
and LiPo 4s
If you would like to see pics and vid of the car just let me know how to put them up
Hayden 09.17.2006 02:19 AM
http://imageshack.us/ for your photos
and as for videos I don’t know do a google search and type video hosting you’ll find some are free
love to see it:027:
Serum 09.17.2006 03:48 AM
Yeah, that is one very fast tourer, with an XL4200!!! be sure to shoot a vid!
Puttinstankonia 09.17.2006 12:55 PM
Yea that car is nice and he is runnin 4s with me but one of my batteries was mislabelled in the pack and the bridged connection is giving me 16.8 volts....
I was trying to charge my pack earlier and the charger kept cutting off sayin battery volts too low... does this mean i have to buy new LiPo's?
BrianG 09.17.2006 01:25 PM
What charger was it? Some require you to enter the number of cells, which may be how the charger calculates the number of cells. If you entered 2S, but the pack is really 3S, then the charger will throw that error.
Puttinstankonia 09.17.2006 03:35 PM
its the red triton charger and it will only allow me to charge at 14.8 volts... but I am runnin 16.8 by mistakes.(packaging mislabeled) so do u think that the LVC on the Quark worked and my charger is the problem or is it the batteries them selves... is the LVC on the quark automatic?
cemetery gates 09.17.2006 04:35 PM
if you are running a 4 cell lipo its nominal voltage is 14.8, its max voltage is 16.8, and its discharged voltage is 12 volts(assuming you set 3.0 volts per cell cutoff, the lowest you want to go)
you have to program the lvc on the quark.
coolhandcountry 09.17.2006 07:59 PM
If you didn't program the lvc on the quark it cuts at 2.7 volts per cell.
Puttinstankonia 09.18.2006 12:06 AM
So does that mean my cells went too low and i would need to purchase more or try a new charger first?
cemetery gates 09.18.2006 12:12 AM
what voltage are your cells at? if they are above 12 volts fully discharged, then you should be fine. 16.8 is the max voltage of a fully charged cell.
Puttinstankonia 09.18.2006 07:39 AM
it seemed as though it might have been at 10. somethin volts and i didnt really pay attention to it because the charger kept giving me the error... do u suggest i try a new charger before purchasing new batts?
coolhandcountry 09.18.2006 04:28 PM
If the volts are to low you can try to drop a cell rating and charge them up to above the 12v mark. PUt is on 3s for the 4s cells. Then swap them to 4s to finish them off. I would charge them slow and keep an eye on them.
BrianG 09.18.2006 05:21 PM
Or, charge them in NiMH mode at a low current and make sure the charging voltage doesn't get any higher than 4ish volts per cell. Once you get t0 about 4v/cell, you can switch to lipo mode. Like CHC said, you MUST keep an eye on them...
Procharged5.0 09.18.2006 07:21 PM
And keep a camcorder running to catch the action just in case.
Puttinstankonia 09.19.2006 12:15 AM
so im gonna try out the Nimh thing and then when the volts get high enough change over to the LiPo and see where i can go from there thanks for the advice ill let you know what happens
