-   -   Gearing Help (https://www.rc-monster.com/forum/showthread.php?t=4093)
Guerilla 09.19.2006 12:48 PM
Gearing Help
:027: Im in need help with the gearing on my maxx
im running the onfa 51 tooth spur. 6s lipos, 1950/8 look for a middle of the range speed/runtime/acceleration gearing.
Any help would be great ?
Thanks
Guerilla 09.19.2006 12:58 PM
Also i forgot to mention if has hotbodies diff's front and rear
coolhandcountry 09.19.2006 01:19 PM
If you have the 3.31 hotbodies diffs. I would run a 15 or 16. If you ahve the 4.3 diffs have to step up some. 19 or 20 tooth pinion.
Serum 09.19.2006 01:21 PM
6S lipo.. that thing will fly!! what lipo's are you using? And what controller?
Guerilla 09.19.2006 03:18 PM
5,000mAh Flightpower Evo20's i think, have you seen the specs on these......
I brought a 24/160 from mike, so that so be good, i really like this controller.
I was thinking of running a pair of 6s wired to give 10,000mAh but i dont know if the weight will be an issue, if so ill go with a pair of 3s wired into 6s
heres a pic of the truck.
http://www.msuk-forum.co.uk/uploads/..._185_64422.jpg
neweuser 09.19.2006 03:28 PM
Nice looking truck man. I love the UE arms. Like CHC said, it depends on the diffs. Use as suggested. If you use two 6s, it will be heavier. i run 5s in mine with 8000 mah, weighs 11lbs exactly. i have the carbon top plates though. I like your front top plate..looks very nice!
Tazz 09.20.2006 08:40 AM
I have a setup alot like yours. Mine has the alum chassis, 1950/7, 2 3s 8000mAh batteries, setback rear arms and 21/66 gearing (that would be about 16/51 for your spur gear). Esc has a fan (MGM 160/24), no heatsink or fan on the motor and everything stays cool. I am thinking about gearing it up a little higher. I see you cut off the right servo mount on your top plate.
