pulling a flywheel?
how do i pull it off?
Sometimesa flywheel puller is necessary, but given you have the clutchbell off, the shoes off, and the clutch nut off, just pry on the sides witha screwdriver gently until it pops off. Be sure to alternate sides though...
thanks squee! will this damage the flywheel?
It shouldn't....
What i do sinice i dont have a gear puller here is what i do . First you take off the clutch bell & clutch shoes & clutch nut. Then you turn the motor over & put the crank shaft on something solid. Then i take a adjustable wrench & adjust it to fit the back side of the flywheel & tap both sides with a hammer & the flywheel pops right off. I hope this helps :027: .
You did the right thing. You should always use the right tool for the job, so you dont screw anything up . |
I just tap with a screwdriver on all sides to prevent possible bending, should fall off with a few good taps
thats what i thought. ofna really had this one on there. my puller made quick work of it though!
On a rare occasion i have had to pry lightly with a screwdriver (very lightly)
| All times are GMT -4. The time now is 10:32 PM. |
