-   Customer Testimonials and Feedback (https://www.rc-monster.com/forum/forumdisplay.php?f=4)
-   -   savage motormount (https://www.rc-monster.com/forum/showthread.php?t=4117)
captanabolic 09.22.2006 12:02 PM
savage motormount
Mike thanks for the mount it fit perfect and boy was it thick that thing is better than chasis braces!!!
Thanks again
THE CAPT
Serum 09.22.2006 12:03 PM
Pics please...
coolhandcountry 09.22.2006 12:09 PM
Yeah I like to see it myself.
captanabolic 09.25.2006 12:40 PM
Here is the savage motormount Mike made for me
<img src="http://i85.photobucket.com/albums/k43/captanabolic/LST/100_0376.jpg">
Serum 09.25.2006 01:13 PM
did it came with holes in the side?
coolhandcountry 09.25.2006 01:15 PM
I orginally designed it with holes in it rene. Mike told me he changed the motor mounting holes to fit the 19 series motor. I don't know how it works with a reg savage chassis.
Serum 09.25.2006 01:16 PM
You designed it for an FLM chassis, right?
captanabolic 09.25.2006 01:42 PM
Coolhand it is your design. Mucho props to you. This is going into a stock Savage X. With a warrior 9920 and a 7 or 8 XL.
coolhandcountry 09.25.2006 01:43 PM
Yeah. The flm exntended low cog chassis. So I not sure what the difference would be. If any really.
I designed it a while back for a 22 series motor and my savage. I still have the mount here if some one needs one for a 22 series. I glad some one else can get some use out of it. Let us know if it works out well on the x.
Serum 09.25.2006 01:46 PM
I think it should work on the X. did you use 2 or 4 holes in the side? and only high positioned holes, or also low positioned holes?
coolhandcountry 09.25.2006 01:49 PM
I used 4 holes for the gas tank front mount I think it was. The frame had it on both side so that is what i used. It was high. A small brace to the back holes would hurt none. Make it just that much better. :D
Serum 09.25.2006 01:54 PM
Yeah, that was what my first design was too (the one i bought in Germany) i made the 2nd longer, and got a small screw in the bottom as well. it made it much tougher.
coolhandcountry 09.25.2006 02:00 PM
I found that insetting the screws made a difference. I guess it took the movement out. but it worked for me. :D
