-   -   Newbie alert (https://www.rc-monster.com/forum/showthread.php?t=423)
cabking 04.03.2005 05:48 PM
Newbie alert
Hello all
I'm running a Hacker C50/Shulze in my Maxx.
can anyone tell me if it is safe to run more than 14.4v through this Hacker?
http://img.photobucket.com/albums/v2...x/PHTO0040.jpg
Any thoughs on this??
Superemaxx89 04.03.2005 08:07 PM
zip tie land!
14 cells i hear is pushing it, but you'll survive. 16 cells is a garenteed burnout.
HotnCold 04.03.2005 08:40 PM
What is wrong with zip ties - I used to use them to hold my batteries in - They were the only thing that would hold them without breaking during the flipping... :D
RC-Monster Mike 04.03.2005 09:07 PM
If you try more cells, gear down a little. You should be safe. I wouldn't go over 16 cells, though.
cabking 04.04.2005 04:55 AM
Thanks for the replies guys
This set up is quite quick but I'm looking for a bit more power.
would it be a better option to get a different motor?
if so which one?
As for the zip (we call them cable) ties. they have soooo many uses, the best of which Ive found is subduing the kids :L:
RC-Monster Mike 04.04.2005 06:03 AM
The 9L or 10L will give a bit more torque. The 9L is great for 12-14 cells, while the 10L is nice up to 16 cells. If you really want torque, the 7xl is quite a beast.
Smurfy 04.04.2005 07:23 AM
Im actually in teh same boat as Cabking
Im currently runnign a c50 on 14 cells, but the c50 is getting very hot, and as such im looking to downgrade teh c50 and maybe chuck it in somethign else.
I 2 have a 18.97.
Im really looking for the most powerfull motor i can use with the 18.97. Iv heard greathings about the Bigmaxximum, but in these very froums iv read the 7XL is almost as good and a fraction of the price.
if you could post your suggestion with maximum cell count that would be great.
RC-Monster Mike 04.04.2005 06:12 PM
The 7xl is a monster for sure. i would think it may even outperform the big maximium in some areas. There is a user on these forums that uses it on 18 cells (9918 warrior controller). 16 cells is a no brainer. Just keep the wires as short as possible (especially with the Schulze stuff) and you should be able to run 16-18 cells with this motor and the 18.97. And it will be a MONSTER for sure in the power department.
Superemaxx89 04.04.2005 08:33 PM
whats the point of a 10L if you can get a 7xl? Runtime?
btw, i like zip (cable) ties:cool:
RC-Monster Mike 04.04.2005 10:24 PM
The 10L is lighter, smaller and will be a little faster on the same gearing. Not everyone needs a bigblock!
Smurfy 04.05.2005 06:32 AM
Thx for the replys, what sort of gearing would you recommend for the 7Xl and UE's 8 Spyder diffs
RC-Monster Mike 04.05.2005 02:47 PM
How many cells?
cabking 04.05.2005 05:58 PM
how about 14 cellswith a 72th spur?? :)
RC-Monster Mike 04.05.2005 06:07 PM
With 14 cells, I would run the 66 spur gear and a 20-22 tooth pinion to start. This will get you to the upper 30mph range(36-38mph). For speed, you would want a smaller spur, more cells and/or a bigger pinion. 14 cells with 22/66 will run quite nice, though.
Smurfy 04.06.2005 03:19 PM
Im really trying to work out the best setup for my e-maxx, but tbh i dont really grasp the basics of what makes a good motor and what makes a bad one.
The e-maxx im trying to build will be for racing on a track.
Maximum cells i really want to use would be 14-16 as any more i feel would weigh the thing down more than id like. The most important factor has to be reliability for me( that means it has to run cool and no chance to thermal the controller as my C50 on 14 Cells is a bit of a hot fecker)
Power is important but i think that may be more about willy waving than practicality. Iv heard the 7XL can run the controller very hard and that a 9L on the same gearing can be faster.
