Gearing again !!!
I´m not sure whta size pinion and spur to but together in my E-Revo - hoping for some help :002:
It will be driving a Quark 125B and Feigao 540c 7xl - 2x7 cell/2x 2s2p 8000 mah lipo. stock diff. I have these spur gears to choose from right now 66 T, 70 T, 72 T, 74 T and 76 T - What pinion gears would match these ??? Or should I go with other sizes ??? What pinion/spur do you use ?? Both torque and top speed would be nice :027: Thanks |
Please use the search button and read a bit.
it might not be the very same setup, but if you read you will understand what selection you should make for gearing. |
don't know much about revo's, but if your using the emaxx tranny, and 32pitch spurs, start at 24/66? I think Serum recommeded this a day or so ago.
| All times are GMT -4. The time now is 10:44 PM. |
