??9920 and plastic center gear??
I was curious about when the BK warrior 9920 controllers would be back in stock cause I know they have been on backorder for quite awhile. Unless I just miss it when they are in.
And I also am looking for a plastic spur gear for my hellfire, it uses a center diff and I am having a hard time finding a gear that I can use with it and my brushless motor. THanks guys, BIG D |
I think you can use a kyosho spur on that. I thought it uses the same cups as the savage.
you could use the hardened steel mod 1 piions mike has against the steel spur on the hellfire. http://www.rc-monster.com/proddetail...ED_PINION_MOD1
Thats not wise....They still don't last for some reason...MacII went through several...The plastic spur Rene mentioned is what you need. It should bolt right up..
I dunno either...
Doesn't mater anyway. They are out of stock too. Have been for a while. :010:
any where else I can get one?
the kyosho's are available thru Mike.
I meant the hardened mod1 pinions are out of stock.
Towers has got some hardened pinions. but they appear to be not so hard...
alright thanks guys, I will have to order me one. (well probably two in case I tear it up)
If you are referring to the Century motor gears from Tower, I would recommend against them. They are not that 'hardened' - I have gone through a 14T gear in about 45 minutes of driving.
I hate to mention the name here, but CF of FD uses a true hardened Mod1 clutchbell with a 5mm mount epoxied in place that may add just a little weight at the motor, but I have been running one in a Kyosho MP7.5 conversion with a metal spur with no problems. |
you got any pics of that conversion? That is my next project
| All times are GMT -4. The time now is 07:53 AM. |
