-   -   Recommendations wanted... (https://www.rc-monster.com/forum/showthread.php?t=4388)
Dunkin 10.20.2006 02:00 PM
can you recommend a brushless system for my Traxxas Rustler. I've rebuilt the truck with all fastlane machine aluminum... it got quite heavy. Upgraded batteries to GP3300's from radio shack... I got the batteries... big improvement in speed with all that fastlane machine aluminum on my truck... but I want lightning...
Pics of truck with the fastlane alum - http://www.rcphreak.com/modules/rustler_rebuild/
missing from those pics is the rear shock tower... added after my photo shoot.
I can afford maybe $250-300... but would like good speed and torque as our track has a few hills and obstacles. I've looked at a few and this one is spec'd for the e-maxx (which is prolly as heavy stock as mine is with the aluminum possibly) what do you think?
http://www.shopatron.com/product/pro...51.17443.0.0.0
and... would I be able to run that system off two 3300 packs running parallel without much trouble?
3300mah \
----| |--- speed control
3300mah /
crazyjr 10.20.2006 02:16 PM
I think a CC.Mamba 4600 or 5700 would run great in that truck, why 2 parallel?
Finnster 10.20.2006 02:20 PM
Don't get the HV, its way too long and heavy, and the TQ will shred your tranny. I doubt your truck is 10lbs, but 5-6+ lbs tho I could see. You mention a track, aer you trying to race this thing? Those alu camber links are a bit silly and heavy, it would be better to get some ball ends and a Ti rod and be truely adj.
Prolly the best bet for your budget would be getting a mamba 5700 or 4600 and either a 3s or 4s lipo. 12NIMH would be very heavy. Exactly what are you looking for? Rocketship fast or just very fast but still ok for a track?
Dunkin 10.20.2006 02:25 PM
Parallel batteries for longer runtime mainly... I did steal some tie rod ends and made my own camber links, worked great. Our track is a 100 foot oval in the back yard that slants down over a little bank at one end, with two whoop-de-doo's in the middle of one straight stretch and a 8 inch ramp on the other straight. It's no professional course and was mainly designed to give us a place to play.
I'm lookin for more speed mainly to keep up with the duratrax evader my friend runs... after a lap or two... he's 3 ahead of me LOL.
BlackedOutREVO 10.20.2006 02:31 PM
well if u want to play on a race track the rusty is not what u should have bought but since u have one a mm will do good batteries wired for runtime could be good because it would stop wheelies ans u need some good tires also..... i dont know if that helped at all but thats what i think
aqwut 10.20.2006 02:33 PM
yeah, I agree.... a mamba max would be plenty for that truck.... The tranny will not last long with 12 Cells.... Well, mine didn't anyways... I wouldn't use 12 cells again.. that's for sure....
sleebus.jones 10.20.2006 02:34 PM
I think the 5700 would be a great setup. A RadioShack 6 cell 3300 pack will give you around 25 minutes of runtime. They perform better if you feel like breaking down the pack and rebuilding it into a SxS pack. With 17/81 gearing, that will put you in the 30+ mph catagory. Need more speed? Make an 8 cell pack and you will be in the 40+ mph range. Still need more? Get a 3S LiPo and you're going to be in 50+ mph territory easy. The 5700 is one of the most versitile motors out there, IMHO. Those numbers are coming from a B4 buggy, and it's geared pretty conservatively, you can go far more insane from there. For instance, I have a 21T pinion...i don't think i'm gonna put that on there, haha! (best guess for that is 60+ mph)
The MM has plenty of power and torque to push a heavy truck around.
Dunkin 10.20.2006 03:19 PM
ok! mambo max it is... just ordered it.
the only fast lane parts not on my truck is the aluminum transmission case, and all gears in there are still stock...
any suggested replacements?
also... MUCH MUCH MUCH thanks for all the advices!!!
crazyjr 10.20.2006 05:28 PM
Are you using the new rustler with the Revo/Jato slipper?
Dunkin 10.20.2006 06:42 PM
not sure, it's model 3705 or 3709 with the XL-5 ESC. I would assume so but haven't compared the two or researched it.
cart213 10.20.2006 06:49 PM
You need to get an aluminum idler gear for the transmission, and RPM bearing carriers and bearings for the wheels.
Dunkin 10.20.2006 07:06 PM
bearing carriers and bearings for the rear wheels or front?
I am running nitro front knuckles, and bearings on the front.
BlackedOutREVO 10.20.2006 07:08 PM
rpm has a line of knuckles that hold over sized berings witch they also sell and a steel idler
Finnster 10.20.2006 08:34 PM
Absolutely these.
My Rusty on 7-8cells has been very tough w/ this.
haha, let me downgrade my rec since that's all your trying to do, a MM5700 on 7cells or so would great. About what my 380c-6L is. I read 12 cells (didn't see the parallel note, and thought you were trying to punch a hole in the space-time continuum.
Any more than this won't really help you in such a race.
Serum 10.21.2006 03:18 AM
LOL
yeah, the stock idler won't last long. It will work, but it will wear/break pretty quick
The mamba controller is a dream to program. You won't be sorry.
