Smoked MGM 80
I just took aout my T2 with a 12s, and 8 cells, and about the 8th run on the ESC, and about 20 seconds into the run it just stoped. I checked all of the wires, quezed the throttle, and a puf of thick smoke came out of the top of the ESC, so i quickly let off the throttle, and shut it off. It was windy out so i dont know what it smelt like. Is it ruined? Should i attempt to rurn it on?
National 80A speedo smoke day..
Viruss just smoked his quark 80... Perhaps the BEC is gone up in smoke. Does the servo works? |
No nothing works, i turn it on and it gets hot, and if i left it on long enough it would probably smoke again, the red flashing light still works thuogh
ygpm!
James, if you got yours thru Mike, you need to contact him about what happened, i am sure he has a solution.
| All times are GMT -4. The time now is 08:06 PM. |
