speed controlls & motors?
what would be a good speed controll that can run brushed and brushless motors, and then what would be the fastest bl motor i could run with that speed controll? it will be in a jrxs i am going to race it so i have to run a 27 turn stock motor well i dont have to but there cheaper than bl motors that would be equal but then a want a speed monkey for at home?
The mamba max can do the job, I'd recomend the 5700 if you are running NIMH's, if lipo's the 7700 would be the one to get
but the mm cant run bolth motors can it? brushless, brushed
yes... it does both.
i cant find anything that says it will................. and how would the mm do a 6 cells? and would the motor clear the belt?
It does...
| All times are GMT -4. The time now is 12:43 AM. |
