Stampede Chassis Conversion Questions
One frustrating thing is that the kit says it comes with everything.
Everything that is except the rod ends. My question is which ones do I need to use? The maxx ones have an inner diameter that is too large so I was thinking These would be the correct match. Also, with the arm part of the kit there are to pieces of aluminum about 3/4 to 1" long and 1/8" wide with a hole at each end that I can't quite figure out what to do with. Any help is appreciated, maybe I am just blind to the obvious but it has me confused. |
If these are the parts you're talking about http://onelouds10.com/flm_what.jpg they attach to the bottom of the rear a-arms. |
Those are the ones, thank you kindly for your help.
No problem. Have fun with the conversion.
I know this is an old thread, but i need to tell everybody that they need to drill the stock traxxas link ends with a .120" or 3 mm bit or you will have split the link endsIf you can even get them started
| All times are GMT -4. The time now is 09:17 AM. |
