recomend lipos please
im runnin a mamba max 5700 and mamba speedy and was wondering what would be a good lipo set up. was thinkin maxamps.
2s or 3s? What Mike's offerings from Maxamps are good choices. What you get should be dependent on your budget.
...and what will fit in your chassis.
ya im thinkin 2s but rightr now i run the stock stampede but im goin to upgrade to fastlane chassis
I would definately recommend maxamps lipos. they are very good IMO
will the 3s lipo fit the stock pede chassis?
The only problem would be height. If you use some custom straps to hold the battery in and remove the rear ESC plate, then it will fit.
i actually think a 2s will be plenty of power. does it matter the mah i choose other then longer runtimes and more power.
Max Amps 2 or 3s lipo, 12000mah!
You'll need a certain minimum capacity depending on the C rate in order to get a rating of about 60amps continuous. For example, Maxamps 2s 4000mah 15C is rated at 60amps continuous, and would work. You can go higher in capacity from there.
alright thanx
| All times are GMT -4. The time now is 11:17 AM. |
