MGM 12012-3s (Anyone Know How To Test)
MGM Will Not Work 4s lipo
-15.12V Incoming -Continuity Through (+) And each Motor Lead -15.12V Through (-) and each motor lead Light will not shut off (very dim) when i turn the controller on it will beep the motor and flash bright, then go done to a dim steady on????????????? |
I think you need to go thru the programming procedure.
I have quite a few times with same result, but at this point I'll try anything!!
You could try reversing the throttle servo on your Tx. It may or may not help.
Seems like it's been forever since I ran my MGM... don't even recall how to program it. But I think I recall that it's sensitive to the throttle neutral point when trying to program it. Keep playing with the radio settings if it's not going into program mode.
the esc was working fine for about two weeks then nothing!!
contact Mike and see if he has any suggestions for you...
Just tried another test. Used an Mtroniks Truck ESC with everything else staying the same. The motor did run but was very eractic on acceleration and never went to full speed it had times for brief fractions of a second that the speed was like my mgm when I first got It . Is it my motor????? How Can I Tell???
Anyone want to purchase my MGM 12012-3s ????????
| All times are GMT -4. The time now is 02:18 AM. |
