-   -   1920 Shaft size? (https://www.rc-monster.com/forum/showthread.php?t=4516)
Sylvester 11.03.2006 11:14 PM
1920 Shaft size?
Hey guys do you know the shaft size of the 1920? I was wondering if i can use standard 1/8 bore pinions with it..
squeeforever 11.04.2006 12:08 AM
I believe so....I'm not sure. It's either that or a 4mm shaft...
BrianG 11.04.2006 02:27 AM
According to this, it's 3.17mm (0.1248")...
Serum 11.04.2006 04:27 AM
Yeah, you can choose between 4mm and 1/8th"
sjcrss 11.04.2006 08:42 AM
I use to have a 1920/8 Lehner motor....and they come with a 4mm shaft...unles you S/O them in the 1/8 shaft
Serum 11.04.2006 09:26 AM
s/o ?
sjcrss 11.04.2006 09:41 AM
S/O means Special Order....in the retail business....sorry.....alos B/O means Backorder in the same business as well
Serum 11.04.2006 09:44 AM
Sorry, i didn't understand it because you used it as a verb. that confused me..
neweuser 11.04.2006 11:36 AM
Welcome to AMERICA, we can't even speak our own language properly! But Shayne is right, they are 4mm
sjcrss 11.04.2006 12:08 PM
that is very true....we have so many acronyms for words.....it isn't even funny.......i guess you can say we are sorta lazy in a sense or it is just easier is all....
Serum 11.04.2006 12:28 PM
Try to speak dutch, you will thank the US for it's easy language.. LOL
Sylvester 11.04.2006 08:49 PM
LOL @ Rene... I wonder if mike has some 1/8 sized 1920s.. thanks guys.
sjcrss 11.04.2006 09:02 PM
you can see if mike can get just the shaft from Bk and you can replace it your self or contact bk and order direct from them....replacing the shaft is real easy anyways.....
Sylvester 11.04.2006 09:04 PM
Still, if i can get it standard with the 1/8 shaft, its alright, besides if i had to switch the whole shaft id also need some bearings.
coolhandcountry 11.04.2006 09:48 PM
The bearings won't change. It is just smaller after it passes the bearing.
