Finale Setup
1.MM ESC $110
2.9xl $ 90 3.6v bec $15 Where do I get the $15 bec? I need gearing for the setup with stock tires and 40 mashers. Do I need to change gearing on the stock setup for 40 mashers? 16/66 |
Mike's UBEC works good, but you can get a $12 one here. I ordered from this guy and the transaction went smoothly.
Gearing?
The gearing is not bad but may have to go up some on pinion size. Get good
run time though. |
| All times are GMT -4. The time now is 12:59 AM. |
