-   -   the question (https://www.rc-monster.com/forum/showthread.php?t=4609)
sweet86 11.12.2006 06:19 PM
the question
i was wondering if it is ok to go a little over the max voltage for a motor. I want to run 12 cells to a mamba max 4600 system but that puts is about 1000 rpms over the limit is this ok.
thanks
Serum 11.12.2006 06:23 PM
The answer..
That would be quite HOT!! what car do you want to use it in?
sweet86 11.12.2006 06:29 PM
either a hpi rs4 or rustler which ever one would do best probably the rustler
Serum 11.12.2006 06:31 PM
are the 12 cells for regular use or for occasional use?
sweet86 11.12.2006 06:31 PM
also wondering what motor would work good on 12 cell with the mamba controler did the math and it needs to ba a 4500kv motor or lower
sweet86 11.12.2006 06:32 PM
regular for bashing and occasional for track use
BrianG 11.12.2006 09:01 PM
The sticker on the back of the 4600 motor does say 3s or 12 cells, but I too think it would run hot. If run intermittently or light duty, then I would say it's ok...
MetalMan 11.12.2006 10:27 PM
I'm running the 4600 on 4s Lipo :p. It does get hot for sure, but the power is fun :). My next battery for my Rustler and the 4600 will be a 3s for sure.
BrianG 11.12.2006 10:45 PM
4s! :dft002: She must run hot at over 68,000 rpm! Must be insane power though.
