What size tires fit?
This is my first 1/8 monster truck and Im having trouble figuring out what size tires of tires go with these wheels:
Maximizer X-75 System Black w/14mm Hex http://www2.towerhobbies.com/cgi-bin...0&I=LXNWP2&P=K HPI Blast Wheel White 115x70mm 7" http://www2.towerhobbies.com/cgi-bin...?&I=LXNHV7&P=7 |
-the maximizer wheels fit the standard size monster truck tires which will give you the most selection of tires.
-the hpi blast wheels are new and you can only use the hpi 115x70 wheels on them and are meant more for looks than performance if your're racing -the other size tire for monster trucks that's popular is prolines 40 series... these are much wider than the other two. ther is a larger selection of tires than the blast wheels but not as much as the standard monster truck size |
The blast wheels are great. They use a 17mm adapter and can be used on allmost any 1/8th truck/truggy. They need HPI tires, which are more bling oriented than race...
| All times are GMT -4. The time now is 11:34 AM. |
