-   -   Successful buggy conversion! (https://www.rc-monster.com/forum/showthread.php?t=4689)
Rcaddict 11.22.2006 05:13 PM
2 Attachment(s)
GlassDoctor is da man. After reading some of his posts about his brushless 1/8 scale vehicles, I was inspired to convert my MBX-5 to brushless. I read everything I could on RcMonster and went with the setup recommended by GlassDoctor. Let me tell you, that setup was dead on. The buggy performed above and beyond my expectations and I couldn't be happier with it. I went with a Neu 1512/2.5d motor, Mamba Max ESC, UBEC, dual 2s6000 MaxAmps Lipos in series and a 14/46 gear ratio. Mike made up a custom motor/diff mount that was a work of art and allowed me to run the Kyosho 46 tooth spur. Thanks Mike, GlassDoctor and everyone else on RcMonster that helped me out.
captain harlock 11.22.2006 05:38 PM
Impressive!!!!
I want a 1/8 buggy, too.
bemmermazda 11.22.2006 08:51 PM
what thickness aluminum are you using for that mount
coolhandcountry 11.22.2006 09:04 PM
That is nice.
It looks about 8mm or 5/16 thick for motor mount.
How the test run go?
Welcome to the forum bmmermazda.
Rcaddict 11.22.2006 09:45 PM
It's 8mm aluminum.
The test run was incredible. I wanted the buggy strictly for racing and the 14/46 ratio was perfect. I can't imagine what this thing will do a 16 tooth pinion. After a 15-20 minute run the motor and ESC were at about 160*. The ESC was very smooth. I had a little cogging from a standstill, but I found that if I eased into the throttle the cogging wasn't a problem. Braking was very smooth too with the Mamba Max. I was a little concerned with the batteries being so far rearward, but after a little chassis tuning that car felt great.
glassdoctor 11.23.2006 02:49 AM
Cool.... glad you like the setup. It's worked awesome for me...
I think it's a killler racer's setup. The 14/46 is a nice starting point.. that's what I was running. But if you really want to see some jaws drop, slap in a 16 or 18T pinion. :) :) It really comes to life then hee hee
That motor mount looks serious! Pretty nice...
Now we just need to get CC to fix the bit of cogging off the line and it's all good.
BP-Revo 11.23.2006 04:12 AM
Wow I am thoroughly impressed. That thing looks VERY good...almost factory...
giftacrylic 11.23.2006 09:12 AM
How hot did your MaxAmps batts get on your test run?
Rcaddict 11.23.2006 09:42 AM
I forgot to check the battery temps. I'll run it again Friday and check that out.
tallyram 11.23.2006 12:59 PM
that thing is nice! hope you're racing next sat. i can't wait to see the look on everyones faces when the race is over. i'm finally going to race my g2r, so we'll just have a brushless party! lol!!!!
BitHed 11.23.2006 10:08 PM
...i thought that if you put your throttle EPA into a negative number on your propo that it would cure, or at least improve the cogging off the line...It wont BURST off the line but its better than sitting there choking on itself...
BitHed 11.23.2006 10:35 PM
...This MIGHT be a silly question but the in the closeup of the motor pic it looks like the ESC doesnt have a case on? You took it off? the thought had crossed my mind but the pros and cons of doing this? I was worried about getting goo in it...Thats not an issue?
rchippie 11.23.2006 11:07 PM
Your buggy looks AWSOME :027: . How did you get the kyosho 46t plastic spur to fit ?. I was told it would not fit the mugen center diff.
Rcaddict 11.23.2006 11:28 PM
That is the UBEC with the white heat shrink. The ESC has the green cooling fins on it.
BitHed 11.23.2006 11:31 PM
...yeah but what about the black case on the bottom of the ESC? I cant see it...Is it on a lower level? Gone altogether?
