-   -   Two Main Questions (https://www.rc-monster.com/forum/showthread.php?t=4745)
GorillaMaxx360 11.28.2006 08:17 PM
Two Main Questions
1.) First I want to know what kind of gearing i should run. I will be getting the 2 hb diffs and the slipperential. I will also be getting the quark 125B, 2 4800 orion lipos, (with heatsink an one fan) and the 7XL motor. My question is what size pinion and spur(revo spur) do I need. I am trying to gear this car for the most speed i can get with out getting in to over or undergearing and cool runing temps. So basically what is a fast but yet effective gear size for speed and efficianty. If you dont mind telling me the exact size of both gear and pionion unstead of the over all gear ratio. The reason i want to know this is because only 1 mod 1 pinion is 25 busck and i dont want to spend 150 bucks tring to find the right pinion. Thanks.
2.) Ok since i will be running 2 2s lipo on this maxx i will be using an external ubec for cool runnings with esc. I will also be running 1, maby 2 fans for cooling reasons. I will also be running 333oz torque servo and a spectrum reciever with 3 chanels( slots for servo, esc, ect...) my question is how so i effectintly wire the quark for two batts. I do not want to wire inside of the box. How do you guys wire you quark for 2 batteries. A pic would be nice of wiring. Also as for as the fan goes can i just wire the one or both fans to a three prong plug and plug it into the extra spot on the receiver will that work. Not much else if you think there will be a problem with any of the setups i have mentioned tell me thanks for your help.:027:
GorillaMaxx360 11.28.2006 08:21 PM
Also Will just attaching the heatsink with zipties still alow the heatsink to do its job or do i absolutly have to use artic silver for the heatsink to work.
GorillaMaxx360 11.29.2006 02:37 PM
could i please get some answers/opinions thanks
BP-Revo 11.29.2006 08:05 PM
I would ask this in the brushless section...there's alot more traffic there and this is a brushless based question.
