Outrunner info??
I was downstairs looking at my unfinished Hyper 8 buggy (waiting for cash) and was wondering what my next project was going to be. I still keep drifting back to a custom dragster/musclecar idea. I thought maybe using a direct motor to rear diff drive system using an outrunner motor may be nice for this. I wouldn't be using a spur/pinion setup nor a transmission so the only reduction would be in the rear diff.
I went to a LHS today and checked out what they have for outrunners and discovered I know nothing about them. Well, I do know the rotor is on the outer can, that they typically run much lower kv, and they have huge amounts of torque. But, I don't know what the ideal max rpm is or really any way to compare them to a typical inrunner style, power-wise. The guy at the LHS said the model numbers (of whatever brand they have) are what they would equate to if it was a Nitro motor. So, a 46 motor would be equivalent to a .46 size Nitro motor. That really didn't tell me a whole heck of a lot. I then asked him what the typical max current draw is and he said the 46 (~800kv) draws upwards of 60A at 11.1v in a plane. So, I asked him if that was constant draw or pulsed draw and he wasn't sure. Also, if 11.1v is the recommended voltage for that motor, then does that mean the max recommended rpm is <= 10k? |
Huh????
Hi,
you can reach much more rpm also with outrunners: I had a Cyclon brushless one capable of 5500 kv/volt and I ran it with lipo 2s. Everything depends by the motor design. They probably shown you some motor to run propellers directly to the shaft of the motor without reductions. I think you should understand how many rpm you need looking for the car gearing. If you suppose you need to reach 50 mph, you simply will find the right rpm using your speed formula "inverted" (difficult to say in english for me, I hope this stay understandable). When you will have understood the right rpm, you will choose the right motor design. BTW have a look to the Cyclon ones, I think they are really good motors. www.cyclonbrushless.com Ciao, Daniele |
From what I understand most outrunners have a relatively low rpm limit because of the amount of mass they are turning. Also, I think most outrunners are much higher pole counts. Like 10, 12 or more poles. This may also have something to do with the extra tourque.
Its actually funny that you say this. I just ordered (ordered on Monday)an ourunner I am planning on testing in a BL Cen Matrix project I am starting. There is actually a company that makes outrunners specifically designed for car and truck applications. www.cyclonbrushless.com I have been wondering about these motors for quite a while but I havent found ANYONE that has tryed them yet. So, I decided that this would be a good place to test it. They are a little diferent than your typical outrunner. They are supposed to be good up to 40K rpm. I'll let you know what happens. Although its probably going to be while since I am lieterally just starting and this is going to be my ''winter'' project. I am going to use the Cyclon Car 2000 (2093kv) motor on 5s (if your gonna test it why not push it right to the limit :018: ) with the Quark 125 set to ''outrunner'' mode. Its the only car controller I have ever seen with a setting for outrunner mode. My thought was I could go with a lighter motor and get just as much/more torque out of it cuz its an outrunner. We'll see I guess... |
Captain: What do you mean by "huh"?
danverz: Thanks. I understand how to figure out the rpms using all the reductions, etc. I just don't know enough about outrunners to know what the "guidelines" are. jhautz: Yeah, I also knew about the high pole counts and the rpm limit dues to the mass makes sense. Since the weight is so far out, it would also act as a flywheel of sorts as well. I wonder what kind of effect that would have. Those cyclone motors look nice. I guess I'll let you be the guinea pig - it's better on my wallet! :) Gotta be careful with the Quark programming though: Quote:
I like the fact that these motors are physically shorter and the lower kv allows me to eliminate the tranny/spur/pinion, which do have some losses. Not to mention it would eliminate any possible weak spots in those areas. |
A direct drive like you are thinking would be pretty cool. You would only need around 3500 RPM to get 60 MPH on a max size wheel. A 240kv ourtunner on 4s would get you over 60 mph. The question is.... Can you really get that much torque out of one motor. :002:
What about getting 2 of them and setting it up on a pair of tank tracks and just use motor speed to steer as well as drive.:p |
I seen a crawler with an out runner in it. It was a little bitty motor.
It had more torque than the 55t lathe motor according to the builder. An out runner has more torque for it has a larger type rotor. It has a 28 mm can. It is like running a 28 mm rotor. He was only running like a 22 something. |
HAH! Awesome BrianG!!! I was going to do the same thing with my emaxx truggy conversion, before i went with a 7XL setup instead.
Here are a few of my notes: THere are few motors that suit car applications (outrunners), HOWEVER, one of the few that i found that would work very well is the newly released E-Flite Power-46 outrunner motor. It's an 800-watt motor, here are specs: -Up to 800 watts of power (continuous, maybe, for airplanes, constant load...) -670 kv (RPM/V) -0.04 Ohm Resistance -voltage range: 14.4-19.2 (4-5 LiPo's) -continuous current 40 Amp, max current 55 Amp -6mm shaft, so you can machine it to take a CV shaft (also reversible) -290 g weight -Diameter: 50mm, Length: 55mm http://www.greathobbies.com/products...d_id=EFLM4046A This motor on 4s LiPi pack should take a typical 1/8 buggy to 45mph direct drive. Or 55mph on 5s LiPo pack. This was the setup i was planning to run, however i did not know enough to actually take out my wallet. I have no idea how hot the motor will run, and also you have zero flexibility as far as gearing (fundamentally). If you want to try that would be cool though ;) Also, on one side of the motor you have to mount it with 4 screws, and the other side will ride on a bearing, you can also take the shaft out and make a longer one to make it work with 4wd setup. The E-Flite Power-46 motor is $130. This setup would be VERY quiet. Almost inaudible, besides the tire noise. |
Well, the one I was actually looking at (just to see it, not to buy) was this one. One neat feature is the reversible shaft so I can decide which way I want to mount it. It certainly looked beefy enough, but again, I just don't know enough about them.
I want to set it up like a real RWD car; motor centered up front, driveshaft to the rear diff. Probably using a custom ladder frame design with 2s2p on each side (to keep CG low) for a total of 4s2p. Maybe use two A123 M1 3s2p packs instead. This type of design would also leave me PLENTY of room to lay out all the electronics on top for optimal cooling. Then, get something like a 1/8-1/10 scale old-style dodge charger body with proline on-road street tires or slicks mounted on mag-style rims. I was thinking of using Revo shocks since they are short and offer quite a range of spring rates. I'll probably make a wheelie bar similar to those seen on real dragsters. I definitely want at least 60mph. Something to turn heads. I'm thinking of incorporating the ability to add weight (steel blocks or similar) in the rear to keep wheel spin to a minimum. A lot of this is on scratch paper right now, but keeps getting pushed aside because I didn't want to deal with a way to reduce ~35-40krpm down enough to use direct drive. For a while, I was looking at using a planetary inline gearbox like this or this, but really don't want to deal with ANY kind of transmission. It's just one more thing to go wrong, and they aren't cheap! One of my LHS places has a bunch of flight guys, maybe one of them knows more about the out-runners. Actually, it would be nice to talk to someone who has used BOTH inrunners and outrunners and knows how they compare. |
[QUOTE=BrianG]Captain: What do you mean by "huh"?
Nothing. I'm quite very simple when it comes to these sort of topics. You talk alot of science:032: and I'm frankly not that type of guy who would dig deep into things like that. I really dont understand many of the terminologies used in this hobby and specifically what regards brushless and all. Haha! I was only joking when I said "huh?", though.:p Do not take me wrong.:) |
Lol, that's OK. It's just that the statement was a little open-ended and was wondering specifically what the confusion was about. :)
The E-Flite has a 6mm shaft that is reversible BrianG, so you can take it out and put in a longer one for 4wd if you ever wanted to. Or to simply flip the motor around...
Thanks for the info. I really want to finish my buggy project first before I start on the muscle car thing. It'll probably be about 6 months before I start on it.
Thanks again all! |
This is interesting Brian. I was thinking the same, the reaso why they have tons of torque is obvious. so is their low KV, My only concern is due to their magnets being relative far from the centre, it won't be as easy to spin up quick and spool down fast. That's a good reason to keep it low kv. (less KV means it takes less energy to spin up)
Their weight is relative low. Which is a good thing too. I thought about putting an output cup directly onto the motorshaft and use two, turning in opposite directions. One for the left, and one for the right wheel.. With the right electronics, and 4 of these babies, you can make your own stabilizing system for corners.. |
| All times are GMT -4. The time now is 07:58 AM. |
