carbon fiber battery straps
Does anyone who has the carbonfiber battery straps (Made by GorillaMaxx) know the distance(amount od space) between the bottom side of the strap and the chassis. Also do you think the team orion 4800 will fit snugly onto these battery straps with no movement(without using the cell adapter just the flat side). And If it wont fit is the gap small enough to put a piece of foam (thicker than stock foam that comes with the g-maxx pads) on the bottom of the graphite strap to make a snug fit. Thanks for your replies.
You can adjust the height.
But... They are not made for flat batteries, because the braces that sits in them give them the strength they needed. |
i know they are not made for them but i figured i could lower them until they fit tight and they would just be pressing agenst them so the support would not matter. would this not work. (-Was is just my computer or was this site down todaay-)
site was down i believe, i was just able to get in!
Quick question does mike cover tax wen you buy from him
When you purchase through the store, that is included.
so when you purchase through the store you pay shipping and tax
I don't think you have to pay tax if you don't live in NY.
what about shipping
ok thanks
So they won't be strong enough rene?
No, it's only 3mm thick, they will turn out pretty round, since the lipo cells are about the size of a 6 cell.
Ok that all makes sense to me.
What if you make some out of thicker cf. |
| All times are GMT -4. The time now is 10:53 AM. |
