Diffing out......
I have a 7XL/Mamba on a Hyper 7 and it runs great on 4s lipo. My only concern is that the batts heat up after a 10 min race. Gearing is 12/46
My question is about the center diff oil wt. and the load on the batts and controller. Which is a better option: Lighter oil (7K-10K) so that it diffs more or Heavier oil (30K-50K) so that it diffs less Thanks |
Lighter oil would make it spin more so would or should be less load on esc.
The thing is you won't have as good of acceration. |
The best thing to do if your battery is getting hot is to get a battery that is more suitable (can handle more amps). The next best thing would be to gear the motor down.
What kind of battery are you running? Mah and c rating?
I am using the "new" 6000 maH MaxAmps batts. I use these same batts in my E-Maxx (5s on 8XL) and they do not heat up at all.
How hot is everything getting?
| All times are GMT -4. The time now is 12:12 AM. |
