my Quark125b esc
4 Attachment(s)
i am mod my quark 125 esc , i use 3mm copper pad stick fet
very great for temperature and not temp issue. i try noload run 30 min use moto 2400kv 14.8v , the moto come to 100c temp, esc come to 52c. some pic: |
NICE done!
A controller normally doesn't get hot when the motor is unloaded though. |
Is that castlecreations wire you used?! :p
Could it be the motor has such a sucky effiecency that it makes to much
wattage into heat? |
NICE! You made me want to try it again!! :019:
Yah, i tried the same thing with running no load... the motor as pathetic efficiency no load, it gets warm instantly! The controller got a little warm. You really shouln't do it though, you could rev the motor past it's safety limit... |
Oh, and yes! I love the wire you used there! What brand is it, and/or where did you get it.
yes i change motor and power wire to castle creations 12AWG wire .
i think is mod no heat problem, if need just add outside heatsink. |
Yeah, you did a great job, no doubt.
Reving a motor on no load is bad... you would not be the first who broke a magnet on his feigao! if it brakes, it can result in a burned down speedo. |
| All times are GMT -4. The time now is 12:20 AM. |
