Eagle Tree MicroPower...
Hey, just wondering if this would work good with my emaxx truggy, running 5s2p A123's, 7XL, and Quark 125. I notice it only has 100 amps max. Wouldn't this setup burst at more than 100 amps?
Any info and experience appreciated |
Yeah, mine showed bursts of 130-150A
So they CAN record higher than 100 amps? Can you elaborate a little?
1 Attachment(s)
Hi zeropointbug,
This is something I made a few months ago. I believe my buggy was running a 4S pack with an MGM compro & 7XL motor in a buggy chassis. Form the pic, it showed a peak current of 114.5A. Regards, Joe Ling |
It isn't able to handle more than 100amps continuously, but it will handle peaks of over 100amps for sure.
oh, ICIC.
Great, thanks Joeling. I was thinking of getting the temp sensor too, would you recommend the wrap around one, or the micro temp probe? |
i got the micro temp probe, you can squeeze it anywhere.
cool thanks
they also have got a rpm sensor for BL motors.
so that rpm sensor, do you just have to tap 2 of the motor wires?
I think i just want to use it for battery temp
I want to log the performance of the A123's in real world, and compare, also when i can get a hold of the Altair Nanosafe cells. |
Get a set of decent lipo's too, you'll see they push out more than the 123's
You can't compare LiPo's to A123's in a voltage stand point (if that's what you mean?)... A123's are a 3.3 volt, it's simply a different battery. But yes, a good LiPo's do put out more relative to their voltage, little voltage droop. I like that, but i still would rather have A123's, safety, charging time, and durability just win out if you ask me. The Altair, i hope are much better in voltage performance. They are also 2.3v, so that will make for more options as far as configurations...
But how much will they drop on a 150A burst.
| All times are GMT -4. The time now is 09:35 AM. |
