9920 12 cells bec or not
is it better to not use the bec on the 9920 in any way
I wouldn't use the ESC BEC. At a servo load of 1.5A, you will be forcing the BEC to dissipate 12.6w of power wasted as heat and will be operating at 41% efficiency.
thanks, the question is for my brothers truck, he" s been running it with bec, i just wanted to know if it made a difference and i see that it does , so he's goin get a rx pack, i just ordered a new 9920 with a ubec just because every one had them , makes a big difference i see
thanks |
:confused: yea.... what he said.... Any load you can take off of the ESC will make your whole system happier:018: Its always a good idea in my book at the voltages that are run in these large brushless setups. |
BTW: those calcs were assuming a 6v BEC output. The values get worse if the BEC actually puts out 5v (which most do)... |
[quote=BrianG]Awww, come on! At least I was brief for once! :)
quote] True:005: It was a very precise answer Brian:D |
:p :p
| All times are GMT -4. The time now is 09:56 PM. |
