-   -   Gearing ? with temps in mind. (https://www.rc-monster.com/forum/showthread.php?t=4975)
rchippie 12.21.2006 07:53 PM
My bl mbx 5 buggy uses a 7XL with a MM with a fan on 14 cells, & the gearing is 13t pinion & 46t spur. The temp on the MM is a round 140 & the motor is 116 at the heat sink & 160 at the rear endbell after 10 minutes under race conditions. Does this sound good or should i change my pinion ?.
coolhandcountry 12.21.2006 08:35 PM
If you like to cool the esc a touch you could try a 12. I would keep eye on motor as well.
MetalMan 12.21.2006 09:08 PM
Sounds good to me! As long as the temps are below 180, it's fine IMO. Do you like the performance you're getting?
rchippie 12.23.2006 11:17 PM
Could my 7XL be under geared or over geared by using a 13t on a 46t spur with the temps i described in my first post or would you be satisfied ?. The speed is great but i might like a little more runtime.
coolhandcountry 12.23.2006 11:30 PM
Well if esc is hot the motor is over geared.
If motor is hot it could be either accually.
If you want a little more runtime try a smaller pinion.
rchippie 12.23.2006 11:53 PM
The ESC is around 140 when i read the temps from the side of the heat sink.
coolhandcountry 12.24.2006 11:10 AM
140 is no prob. The temps are good accually.
Just not sure if you want cooler or not.
