Lvc ?
Where do I find the LVC on Mike's site? He said it was auto detecting and about $30.00 I can't find it.
The hautz man has hooked you right up.
He pointed you to the right direction. |
The good thing is, it's the car version!
Yeah, normal plane lvc's go to 0 percent.. since 0 percent is full reverse on pistol grips, i guess you can tell what will happen if it kicks in..
I know this thread is a little stale but I was looking for an alternate LVC other than the "li-saver" for my nearly complete Cen MAtrix since it seems a little harsh when it kicks in on my LST . This discussion made me look to see if there really was a "Car" version of this LVC and don't see anything but either "Opto: or "BEC" versions. http://www.flydma.com/catalog/produc...products_id=53
Only difference is the way the ESC is coupled up apparently but no mention of anything other than the airplane version that pulses the motor on and off when the voltage drops.I wonder now if my perceived harshness of this LVC isn't caused by Serums observation of the "0" positions of the pistol vs stick type radios.Does anyone have an alternative with perhaps a softer alarm ......slowing the truck gradually instead of trying to force it into reverse?? Thankfully reverse is disabled on my esc or I suspect things would be even worse with that LST tranny and 2 speed trying to go in reverse.:007: Anyway Thanks in Advance pinolelst |
OK... I cant really help you with the LVC question, but I am interested to hear the answer too.
However, I would love to see pictures of your Matrix conversion though. I love my Matrix conversion and Im interested to see how you did yours. |
3 Attachment(s)
This is where I'm at.Waiting on the feigao 540c 8xl to get here and the new body to finish it off.I made the battery holder from carbon fiber 80/20 cloth laid up in 4 layers with a piece of depron foam sandwiched between the 2nd and 3rd layers on the bottom so I'd have some depth to cut holes for the mud guard nuts.I used a block of foam as the form and wrapped it with cling wrap to act as a release film and wrapped the outside tightly with the same stuff to give it at least a 1/2 baked finish.
The battery strap bolts are holding it to the deck as well as velcro on the inboard side to act as a sort of leveler. I also epoxied together some carbon ribbon I had laying around to make the BEC/receiver mount to get them up off the deck.I need to find one of those antenna expansion nut doohickies that fit in a drilled hole or fabricate something for the antenna as well. thanks pinolelst |
I like it. It looks good. With that CF battery tray and the layout it looks alot like mine. Looking forward to finding out how it runs. Keep us posted. What kind of lipó are you going to use?
How many cells can be used with this with this Li-Saver. Is it good for 4s applications?
What is wrong with the li saver? As long as you get the car version you ok.
Just looking for alternatives that perhaps don't go off so violently.Maybe it's specific to the LST and it's drivetrain but the dang thing bucks like it backfired or something when the LVC kicks in.... Thanks pinolelst |
The ones mike sells is supposed to be a car version. I haven't got it down far enough to know yet.
Just curious: what is the volts/cell cutoff value of the Lisaver? Is it 3v?
| All times are GMT -4. The time now is 08:08 PM. |
