tires, tires, tires
im runing stock emaxx tires right now and plan to get new tires soon..does any know of a good tire that can be used on dirt and asphalt????:032:
try the stock revo tires.. Thats what I'm running now (bashing around) and they perform great on both surfaces.. used to run bowties..
phil |
most tires will wear faster on the asphalt. I have run the crimefighters on the both.
coolhand what do you think of these for asphalt use......??????
http://cgi.ebay.com/HOT-BODIES-SLAYE...QQcmdZViewItem |
They look good. Don't know how they do? Never ran them.
I really like the Losi ZombiMaxx tires for all an all around tire. Runs good on dirt, grass an asphault. They handle decent for an all aroud tire and they dont wear out to quickly either. Been bashing a set for quite a while and they still have a ton of tread left. Only sugestion with them is to belt them with duct tape or they will balloon like crazy.
http://www.horizonhobby.com/Products...odID=LOSA7670R |
The hotbodies tires look nice! too bad they have a 14mm hex, and the HB rimms are not known for their strength.
Hotbodies has some 17mm rims.
I hope they are stronger. I plan to put some power on mine. |
I like those tires, seem to be more street though.
| All times are GMT -4. The time now is 05:27 AM. |
