cooling fan?
I just purchased a 9920/9xl combo to be run with 14cells. What fan should i use on the heat sinks? Where can I order them?
I use a 5V 25mm Novak fan zip tied onto the fins.
http://members.cox.net/tg_19/BL2.JPG I got mine at Tower Hobbies. I'm sure they are easily available elsewhere. |
Thanks for the reply. Nice set up! :027:
Are those lithium batts worth it?? |
Lipo is worth it!!!! Personally, you can get a better fan to blow more than that and cheaper too. Maybe someone here can give you the link. I bought two 40mm 5v for 5.00 or so.
I use the one for novak hv maxx. It has it own mount and stuff.
I think the lipos are worth the money. |
Post them! always like to see the work of others.
Riceman; why didn't you put your L braces the other way around, the lipo cells can use the support. |
| All times are GMT -4. The time now is 01:48 PM. |
