Neu 1900 motors
Hi all,
Has anyone tested or considered using a Neu 1900 motor in their conversions? They're highly regarded motors in the heli world, offering very similar performance and Kv spec as outrunners, but they're 8 pole inrunners. What do you think? Thanks, Aragon |
Actually, yes there is one 1/8 buggy that I know of that has a 1900 series Neu.
http://www.truerc.net/canada2/projec...projectca.html I, personally would not use a 1900 series Neu. I would use a Neu 1521. It has a max power of about 3000 watts, which I think is more powerful than the 1900 series. Also the mounting holes on the 1521 are the standard 25mm spacing, but the screw size is 4mm. Which, I think, would be easier to mount in a 1/8 buggy... Bye:018: |
CG, that's the setup that sparked my curiosity in the 1900s. :) Neu rate them to 3000 watts too BTW. Since the TrueRC setup the 1915 has been released.
Top ESCs in heli world are considered to be Kontronik and Schulze - both are used with these motors. Schulze seems to have a rep of smoking in cars, and Kontronik doesn't seem popular for some reason... Do the car specific ESCs need 2 pole motors? |
MGMs can run 4pole motors fine.
What would you use a 1900 series motor in? |
Does any one know the sizes on the 1900 series?
49mm thick, 25.4mm to 57mm long.
| All times are GMT -4. The time now is 05:42 PM. |
