Quark Woes..
Hello, I have been having a bit of trouble programming the quark 33 pro car 1/18th controller. I have everything set up properly and I programmed the nuetral position on the transmitter and such. All is well until I turn it on about 20 minutes later, all I get it is a continuous beeping alarm? I looked in the manual and troubleshooting on their site, and no luck figuring out the issue yet. It won't even let me reprogram the esc.
Edit: I have the female plugs on the motor and the male on the esc... could this be causing the problem? |
I don't think the plugs have nothing to do with it unless it has a bad connection.
Did you ask quark thru email or phone about it? |
Call Sky Technologies....they are awesome. 310 527 0002
I would say that the plugs being on the wrong end has nothing to do with it. I just programed mine last week with issues as well. Their instructions definitely need help (or maybe I do....Ok, it's probably me). Your best bet is to give them a call. I personally couldn't find any answers on any web site or forum.
Btw, what are you putting it in? What motor did you get and with what batts? I can't believe the speeds these little things get with these setups! |
I had a little trouble programming mine, and I found I needed to move the throttle a little bit to the reverse side. It was like the neutral spot wasn't neutral enough or something.
As far as the setup goes..
RC18T - Mamba 6400kv - IB 1400 6 cell - Airtronics MX-3 - Some unknown brand heli micro servo. I sent them an email, however, I am guessing that they are on a holiday break. EDIT: I figured things out. Turns out I had accidentally programmed in the LVC for Lipo... so that was the alarm going off. Charged it and did some serious 180->360-> infinite loops (concrete floor). Seems to pack some serious punch. Now if only it would stop snowing and raining. |
Glad you got it figured out! |
I've been running mine alot lately too. The weather here is starting to change and get real cold here. Should dip into the high 60's this week so I need to get in all the driving I can before it gets too cold.:005:
You better hurry. It may hit the lower 60S before long. :D
Gasp!! Low 60's! I better grab my snow jacket!
haha.. we went from raining and no snow to about 2-3 inches on the ground today. I set up a small jump with cardboard and a bench last night...allowing me to run it around the basement a bit. This thing needs some more room to open up though. I forgot its 7 cells and 5400kv motor.
| All times are GMT -4. The time now is 02:11 AM. |
