aluminium parts
give me your toughts on alu suspension components
is it worth it? |
Depends on your application, what your driving style is and such, as well as personal preference. Fore surely stay away from aluminum bumper mounts, body mounts, these are places you want some give.
That's absolutely correct! I'll second that! RPM is a good spot to go for replacement arms that don't cost much but hold up well and you can get colors to dress up your truck (yes, they are plastic but worth mentioning) After that look into Fastlane machine. Decent arms and a great warranty! Then the topdog! Unlimited Engineering 3 levels available depending on your budget and application. BEAUTIFUL well engineered products! I've owned the UE Widetrack and the UE Racer-X both are awesome! |
hey guys i have more Q's bout alu and tought; i'll ask here.
can this tube be welded? 6.35 mm OD x 1.65 mm WALL x 3.05 mm ID 6061 T6 TUBE or is that impossible due to thickness or size? would have to be welded onto other pieces of same tube and onto this: 6.35 MM ALUMINUM 6061-T6 PLATE ??? thanks. |
Aluminum can be welded with specific rods for the application. Depending on the size, you need to adjust your current to do it. But you would have to be pretty damn good with pieces that small without melting them into nothing.
DO NOT "STICK WELD" IT!
To weld someting that thin you need to MIG or TIG weld it. Both methods are equally strong but TIG allows the welder to better control the process and the appearance will be nicer (the "weld bead"). I'm set-up to weld steels, including stainless but I need a new liner for my weld gun/feed hose before I could do any aluminum welding, othrwise I'd offer to help. |
Good point! I knew you knew the difference!
I thought I'd share just the same. Maybe I should start building a Modified revo chassis for use in conversions? I'll wait and see how the other member on the forums does...see if he builds them or not before I look into it or crank up the welder. :-) |
i see, you need mad welding skills and a tig or mig.
thanks guys. not that i have any of those 2 but i know a place where they have people that weld alu all day. |
that's cool, you should be set then, just advise what you want and they should be able to hook you up!
the thing is, i dont know if they would do such thing for the normal man.
normally they built dumpers. and fix trailers. |
you really think so? damn.
| All times are GMT -4. The time now is 08:50 AM. |
