-   -   Recommend me a Lipo pack (or two) for a BL Jato (https://www.rc-monster.com/forum/showthread.php?t=5126)
fiero_silva 01.03.2007 01:11 AM
Any recommendations on a size and/or model of Lipo pack for my brushless jato running a mamba max system?
I'd like to run 3s, or 4s if the controller will handle it.
Looking for 20-30 minutes of runtime...
GorillaMaxx360 01.03.2007 01:59 AM
Maxx amps 8000mah pack you can get it in 2,3,4,5,6s i think. They give you awsem runtimes and good punch.
fiero_silva 01.03.2007 02:06 AM
My charger can only do 3s, so if I go 4s it would have to be a pair of 2s packs.
Is 8000mah not a little overkill for my application?
BP-Revo 01.03.2007 02:24 AM
Not at all. It is more than enough current capabilities and it will give you tons of runtime.
If your charger only does 3S, then use only 3S and use a higher KV motor. It will simplify things in the end.
jhautz 01.03.2007 03:47 AM
4s 8000mah in a Jato is a huge pack for that vehicle IMO. I can run my rustler a half hour on a 4200Mah 3s pack. That should be more than enough juice for your needs. And it wont weigh you truck down as much.
I'm running it on a 9L and a warrior 7020.
(actually, I can almost never run a whole pack through it before I break something anyway. Its slightly over powered:p )
