Cut off on 37V lipo
i'm going to bulid a brushless fg, i'm going to run with 37v lipo (18.5Vx2)
But is there a way to get cut of on this setup At maxamps i can find cut of for 5s lipo, but can i use to of them? One to each battery, is so how do i wire them? |
thanks that wil work
yea and its only $20
I have that one, it kept locking in to full throttle and shooting off, had to take it off.
It was bad because you didn't know when it was going to do it, so I had to go really slow, lol.
Not seen anything under the label but it definatly feels like a malfunction/interference rather than programming. |
Yeah, i contacted dimension engineering about it a few months back. They told me it would be fine to use it on a truck.
What??? Shoot off? Thats horrible...not only bangs the truck up, but fries that pack too!
I know I was stating the obvious...but its fun sometimes lol... |
I'd like to get a hold of one of those to see if it could be easily modded (any donors? :)). Since it goes into full forward when triggered, it simply puts out 2ms signal pulses to the ESC telling to go full bore. If an adjustment was added to reduce this to 1.5ms, it would go to neutral instead. You could also set it to put out 1ms pulses instead so it goes full brake instead too...
True. I guess my point is that it would be nice if it was adjustable to whatever application...
Per Serum's suggestion, I got one of these and run it on my 5s Maxx. It works great, ONLY if you don't have reverse programmed.
Yup, that would do it! Sounds like it would work great if you have reverse disabled.
| All times are GMT -4. The time now is 09:35 AM. |
